Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
I'm stuck in safemode
Safemode tried reinstall shows code SU-101326-3
1 Comment
Following. I too am stuck in safe mode.
by
Add a comment
Most Helpful Answer
Hi!
This error code is related to the disc drive unfortunately.
It need the disc drive in order to update the system. If the PS5 is not able to recognize/detect the drive, it won't update and show you that kind of error.
So, the only option is to fix the PS5 with a working disc drive. It's not the laser that is broken most of the times when this error is caused. It's probably the cable or the drive it's PCB.
Guide: PlayStation 5 Optical Drive Laser Replacement - iFixit Repair Guide (this one is for replacing the laser, please skip that part).
Please let us know how it goes!
Score 1
1 Comment:
Hi,
I got the same error i was able to fix it on my own. Does your ps5 run eject loop every 10 or so seconds? If yes then just unplug the 2 pin red-black connector on the disk drive. Then try few times. Make sure you have correct reinstallation or update file. They both are different.
by
Add a comment
Well this often shows up during attempts to fix problems like being stuck in Safe Mode, software corruption, or after a factory reset. and issue with the USB drive or file structure. So I will suggest you to check out the following factor and also checkout the following video: https://www.youtube.com/watch?v=DR9YinUL...
Add a comment
Add your answer
mark b will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 202
