Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
100 Questions View all
MacBook Air shows vertical lines and double of image. What's broken?
My Macbook shows vertical lines and parts of the image are doubled in the buttom half of the display. Can someone tell me what's broken - and will changing the display fix the problem? If I use an external monitor - there are no problems at all...
Thank you very much and have a nice day.
Jakob
2 Comments:
@kokoele - What is your exact model? There are quite a few MacBook Air models. Look as the About this Mac menu to get the info.
by
Its Model is A1932. Thank you very much!
by
Add a comment
Hi
I have a 2014 MacBook Pro that I bought broken and it had this issue
I had to unplug the display and plug it back in again then good as new as if nothing ever happened
If that doesn’t work you may need to replace your display
Hopefully this helps
5 Comments:
Thank you very much! I tried to plug everything out and in but in again - but it didn't work.
by
@kokoele
You might need to replace your display unfortunately
by
@kokoele
Just out of interest
You didn’t drop it
Sorry I’m just assuming it came on randomly
by
No it came just randomly.
by
@kokoele
Your probably going to need a new display assembly
But there’s one last thing we can try
Carefully remove the display and inspect the 2 ribbon cables that come from the display,if you see any dust or debris on it CAREFULLY remove it , I really do mean carefully as we don’t want to make things worse:-)
by
Add a comment
Sadly you need a new display assembly, something heavy sat on your system and/or got a bang in the wrong place.
Here's the needed part MacBook Air 13" (Late 2018-Early 2020) Display Assembly and here's the guide to put it in MacBook Air 13" Retina Display 2019 Display Replacement
MacBook Air 13" (Late 2018-Early 2020) Display Assembly Image
Product
$459.99
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 89
