Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Why can't I plug in my earphones?
One day I unplugged my earphones to hear it out lound, then when i tried to plug them back on, the earphone's input wouldn't go in all the way. I want to kno how that happen and what can I do to fix it please im desperate.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hey Chava, it probably got clogged with debris. I've cleaned a few out and I'll share the method I used to unclog the headphone jacks.
First thing's first you have to be extremely careful because at the bottom of the headphone jack, it's only protected by a thin strip of white plastic. If you break through that you'll have to replace your iPod altogether.
Get the smallest tweezers possible and try to get the debris out. Normally this doesn't work though, so I usually have to get a toothpick and CAREFULLY try to dislodge the debris and drag it out of the headphone jack. A slow process, but the end result is worth it.
When it's all clean, you can take a cotton swab and dampen it with isopropyl rubbing alcohol. Take care here as to not soak the cotton swab, but dampen it just a little. This will clean up any dust and/or dirt left on the sides of the headphone jack. Good luck!
Cheers!
-Graham B
Score 2
1 Comment:
I was just looking at the conversation between you two. Thank you for the suggestion. I was looking all over the internet for a reason why my headphone jack would not go into my iPod touch. Thank you again. :-)
Cheers
Anthony H
by
Add a comment
Add your answer
chava will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,027
