hp envy x360 15m-ed0023dx won't turn on
My hp envy x360 15m-ed0023dx won't turn on; no lights or screen display or fan noise: completely dead. The power jack lights up when plugged in and I can detect voltages on the motherboard from the power jack to the battery, which also shows power. The one fuse I located (marked fu2) has continuity and the power button* (integrated in the keyboard) checks out good as well. I tried a hard reset a couple of times but no luck. Also tried pulling the ram and replacing one by one. No change. The power supply checks out good. At this point I'm thinking it's a bad motherboard so I ordered one.
This is a little difficult to believe since the laptop isn't even 2 years old. But unfortunately out of warranty.
How I checked the power button
First I separated the palmrest/keyboard assy from the screen. Then I placed a foam rubber "foot" on the power button.
Then I flipped the assy over so it rested on the "footed" power button which activated it and enabled access to the motherboard keyboard cable. In the picture the motherboard is removed, with the keyboard cable taped down with pin side up. Using a multimeter equipped with needle-sharp (fine-tipped) probes, I tested the pins in pairs (figuring the power button involved two pins) until I discovered the relevant pair, counting from the left pins number 13 and 14, which showed continuity, so the button is good.
14 Comments
Update after installing supposedly good replacement motherboard. After doing a hard reset, I was able to start it, with fan running but no screen display. However, after managing to start it a couple of times with no display or error beeps, I was unable to get it going again. I rechecked the battery and power supply = both good. I then tried a new power jack, but no difference. I removed the memory and put them back in one at a time, and also no memory at all to see if I could get a beep error, but no luck. At this point I'm perplexed and will go study the service manual to see if there is any secret procedure necessary to start the computer (like, does the back cover need to be in place for it to start?). Will check back later. If anybody has any ideas, I'd appreciate you sharing...
by PC Techneer
Hi @PC Techneer
You don't say if you tried connecting both to an external monitor or TV to see if the screen was the problem.
by mike
@PC Techneer
What is the make and model number of the motherboard?
Do you get any indications on the laptop if the charger is connected but the laptop is not turned on i.e. just charging?
by jayeff
Update: After allowing the laptop to charge overnight I felt the battery and it felt cold to the touch, so I'm thinking maybe the battery is bad, and I ordered a new one and a new power supply as well.
by PC Techneer
@aactech The laptop wouldn't turn on, so connecting it to an external monitor wouldn't be helpful, but thanks for your reply.
by PC Techneer
Show 9 more comments
