Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
After replacing Digitizer & LCD, there is still no response on Digi?
After replacing the Digitizer & LCD to a customer's iPod Touch 4th Gen, I still get no response from the screen. I know it's not the screen because i swapped out four different Digitizer & LCD screens. The LCD screen lights up. The connector to the Digitizer does not look damaged at all. The broken screen worked just fine before I removed it.
Any ideas?
Add a comment
It sounds like the the cable connector is not plugged in .
Or the cable itself is damaged even though it looks ok.
Or else you got a bad dig/lcd assembly.
Only thing to do is try a new assembly. Good luck.
One thing eveybody should do is to test it before glueing it down.
1 Comment:
I've tried four different screens. Still having the same problem with all four screens. And I did end up putting those four screens in different ipods, and they worked in those.
by
Add a comment
The only other assumption is that the connector on the motherboard is broken. Must have gotten damaged while trying to plug it in.
I feel your pain.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 594
