Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
After replaced the battery, it won't charge
I've replaced the battery on my 3G. During the replacement, the #4 connector to the docking connector was ripped (it stuck to the bottom of the faceplate assembly) when I pulled the suction cup. So I had to replace the dock connector as well. After all is done according to the guide, it won't charge the battery. The phone was plugged in the whole night and in the morning it showed the battery is completely drained, even with the charging sign on.
What happened? Should I ask for a new battery?
Score -1
Add a comment
1 Answer
Most Helpful Answer
3g and 3gs batteries are not cross compatible. make sure you got the right battery
Score 1
Add a comment
Add your answer
klin168 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 639
