The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
45 Questions View all
My Samsung phone won't let me call out
I can't make it receive calls on my Samsung phone but I can still text and use internet what do I do
Tried turning it off n back on n tried airplane mode on and off but nothing works to get the calling option to work texting n internet are working fine though
1 Comment
I can not make calls on my Samsung S10. I can receive calls and send text messages but I cannot make outgoing calls
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
Try the following and check if it works OK or not.
i). Wipe the cache partition and check if it works.
ii). Start the phone in safe mode and check if it works OK.
If it does then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app one by one and test the phone in normal mode to see if it works OK. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and wasn’t pre-installed when you first got it.
Score 1
Add a comment
Add your answer
Christina Collins will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 154
All Time: 726
