Battery Not Charging, Only 1.2V at Terminals
What could cause an Ipod Touch 2G to only have 1.2v across the battery terminal when plugged into USB? I replaced the battery with a known good one and the issue remains. When I remove the ipod from the USB cable, the voltage drops to 0.25v.
I dont know if it could be the charing port or the Power Management IC?
Thanks!
Comments:
I left it plugged into an AC adapter for a few hours and the results are the same. Not sure what else to check. I think something may be shorted out...??
by
Check your dock connector and see what you get. Checked the connector to make sure the pins are okay? Also, your battery is a new one or used one? I'd go with the easy stuff first.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
AnthonyM84, before you plan on changing anything further, plug your iPod into an AC charger. Your battery is discharged to a point that the USB port will NOT charge it. It is basically to far down for the the USB to charge. An AC adapter will be your best bet. Your battery may be a known, but to low to charge.
Score 3
Comments:
How do I check the dock connector? The battery was taken from one that was working just prior and is less than a month old.
by
Add a comment
Pin 1 or 2 - GND
Pin 18 - 3.3V Power (+)
Pin 23 - USB Power 5 VDC (+)
Looking into the dock opening pin 1 is all the way to left and pin 30 is all the way to the right.
Score 2
Comments:
+ good answer
by
Add a comment
Add your answer
AnthonyM84 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,044
