The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Can I connect a battery to the MacBook while it's running?
TL;DR, I got a dodgy battery that doesn’t like to charge, so the battery is disconnected right now and I’m using the laptop in AC-only. What happens if I try to plug the battery in while the Mac is powered-on and running?
Score 1
1 Comment
Don't do it!
I tried it without thinking - old battery was disconnected, laptop was in AC-only, then I plugged the battery. Instant turn-off and laptop doesn't respond anymore. Charging shows orange.
I wonder what's broken now. I'm waiting for a cheap $5 DC-in board to arrive but if that doesn't fix it my guess will be that the logic board is dead :(
by
Add a comment
1 Answer
Chosen Solution
I would’t try that if you have a dodgy battery! You could damage the logic board charging logic. How about we figure what’s happening.
Let’s first disconnect the battery as well as the MagSafe charger (any anything else thats plugged in the ports). Now press and hold the power button for 15 sec so we fully discharge the logic board. Now carefully plug in your battery and then the MagSafe charger. You’ll want to have already setup a ISB drive which you’ve already downloaded CoconutBattery as you’ll want to install it to your system and take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Score 1
2 Comments:
Unfortunately I read your answer too late and plugged the battery while powered on. Now it's not responding anymore (same as before with the battery actually). What did I likely break and do you think it's fixable Dan?
by
@Stéphane Bruckert - Time to visit a Mac repair shop ☹️
This needs either just a fuse or a MOSFET is blown
by
Add a comment
Add your answer
Darth Vader will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 133
