Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Audio software problem iPhone4, only the right side is working!
I have headset problem on iphone4. When i plug in my headset, the left one its not work, only the right one.. Eventhough i can hear from the right speaker, the sound quality very bad, the noise keep comming out at maximum volume (100%). And when i turned the volume less than 75%, the sound suddenly disappear.. i've got stress with my iphone4.. I think its the software  problem..  I also try used so many other headset, but still same, the left one its not work, only the right one.
The only way to hear music i using bluetooth headset.. When i using bluetooth headset it works very well, but i must charge my bluetooth headset battery everytime before use that, and also it will drain my phone battery if i always turn on my bluetooth.  ㅠ_ㅠ i've search on google, every iphone forum to solve my problem, but i got nothing..
If the problem is the audio jack connector, so why when i turn down my volume less then 75% the sound at the right speaker suddenly disappear? And why the noise keep coming out at the right speaker (volume upto 75%) ? i also upgrade my version from ios 4.3.3 to ios 5.0, but still same... ㅜ_ㅜ i don't want to go to apple service center, because my iphone is already jailbroken..  I wanna try to replace audio jack connector with the new kit, but i think it will useless if the problem is the software.. Right?
Somebody please help me.. I'm sorry if my english bad ^_^v
1 Comment
m iphone is coming on n of if i put it on a charge idnt now de promble Hlp plz
by
Add a comment
Chosen Solution
If you have a friend with an Iphone 4, switch the Headphone Audio Jack Flex cable to see if his/her have the same problem with your cable and to see if his/her cable work fine in your Iphone. Trial and error saves money. :)......Thats a starter.
Add a comment
Have you visually inspected the inside of the headphone jack for dirt, lint, or any other obstructions? If anything is in there try taking a fine tip and digging it out.
If no obstructions you will need to replace the headphone jack assembly.
Good luck.
Add a comment
Thx Chris, u right, i should try switch the audio connector from another iphone4 to make sure what is the problem before i buy a new audio connector flex..
Thx also to Garry, i have try to removed the audio jack from device, and i've checked there is no obstructions.. I've do this for twice lol
Add a comment
I have found that I have the same problem this week and think it is a software issue. Just before this happened I updated to latest iOS, 6.1.3. I haven't dropped it, or gotten it wet. I've restarted it, reset it, and restored it. Nothing has fixed it. Plugged my headphones in this morning and it started playing a podcast without me turning it on, the audio was garbled, sounding like a bad acid trip. Restarted it and that settled down, but audio still out on left side. External speakers not very loud either. I am pretty darn !!&%^# right now.
Add a comment
I have also the same problem . My headset won't working properly? how can i fix it ?
Add a comment
Add your answer
Hendry Yadhisna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 10
All Time: 3,664
