Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
don't charge connected to mac nor seen by itunes
iphone 3gs 16 gb, never had issues, now it charge and keep switched on only connected to power supply, if add the link to mac, black screen, if link to mac, black screen. Impossible to switch it on on its own only reset when connected to power supply.
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like your battery has run out of charging ability. It will need to be replaced. Buy it here or many places online/phone shop.iPhone 3GS Battery Replacement
as with any repair on a 3GS please remember to hold power button until "slide to power off" appears or you risk damage to the LCD backlight. good luck.
Score 3
5 Comments:
Many thanks, well, actually I did it already... with an apn 0433 instead of an 0435, but the issue was already present...
by
so you changed the battery and have this issue?
by
Had the issue, thought it was battery fault and replace it, issue still there
by
could be a bad battery or poor contact between battery and motherboard. Make sure the screws near the sticker/connector 7 are in properly to give good contact.
by
it is FIXED! Thanks a lot Pollytintop, guess you were right, checked 5 times all the connections and fixed it. Your are great guys!
by
Add a comment
Add your answer
Massimiliano Gazzale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 324
