Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Slot de memória em curto
Hi, My name is Carlos. I’m from Brazil
I have a Mid 2010 13” MacBook Pro A1278. Memory Slot 0 (next to the motherboard), must be in trouble. When I put a SO-DIMM stick in it, the equipment turns on and does not upload video. When I put the SO-DIMM in slot 1 everything is normal.
How to replace the defective slot?
I will be grateful for someone to send a step by step.
Thanks.
Add a comment
1 Answer
Sadly if the memory slot is bad there is little you can do other than replacing the logic board.
Let’s give this a try first! Carefully loosen one quarter turn the four screws which hold the memory socket frame.
Make sure you are using the correct SO-DIMM RAM - 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM
And keep in mind this system is limited to 8GB using two 4GB SO-DIMM’s
Add a comment
Add your answer
universidadedelphi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 31
