Model A1213 / 8, 16, or 32 GB capacity
216 Questions View all
Battery or Dock Connection!
I have an older itouch first gen, when I charge it it doesn't hold the charge, can you tell me if this is more likely a battery or dock connection issue? It does take extra effort to show when it is connected to charge... seems looser than in the past
Score -1
Add a comment
1 Answer
Chosen Solution
Being a first generation it is likely a battery. You can visually inspect the dock connector to see if any pins are missing, bent, or a buildup of debris. However, if the dock was faulty you may get no response when plugging the device in. The batteries are not made to last forever (planned failure).
This repair requires solder, but is the easiest of the touch batteries to install.
Good luck!
Add a comment
Add your answer
matt119 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 364
