Won't sleep when lid is closed
Macbook doesn’t sleep when lid closed. Tried reseting PVRAM and SMC and reinstalling OS. Replaced the screen assembly about a month ago. Replaced the battery a few weeks ago. Everything worked, it seemed, after both repairs. No water damage.
Update (10/12/2020)
No apps in activity monitor are preventing sleep.
Here’s the response from terminal for pmset -g assertions
2020-10-13 01:32:16 -0400
Assertion status system-wide:
BackgroundTask 0
ApplePushServiceTask 0
UserIsActive 1
PreventUserIdleDisplaySleep 0
PreventSystemSleep 0
ExternalMedia 0
InternalPreventDisplaySleep 1
PreventUserIdleSystemSleep 0
NetworkClientActive 0
Listed by owning process:
pid 315(UserEventAgent): [0x00001c7e000b9def] 00:00:13 BackgroundTask named: "com.apple.knowledgestore.sync"
Created for PID: 320.
pid 315(UserEventAgent): [0x00001be9000b9dac] 00:02:42 BackgroundTask named: "com.apple.coreduet.sync.triggered"
pid 143(hidd): [0x00001bd900099d9f] 00:00:00 UserIsActive named: "com.apple.iohideventsystem.queue.tickle serviceID:100002428 name:AppleHIDKeyboardEve product:Apple Internal Keyb eventType:3"
Timeout will fire in 60 secs Action=TimeoutActionRelease
pid 101(powerd): [0x00001c3d00108001] 00:01:18 InternalPreventDisplaySleep named: "com.apple.powermanagement.delayDisplayOff"
Timeout will fire in 41 secs Action=TimeoutActionTurnOff
No kernel assertions.
Idle sleep preventers: IODisplayWrangler
Can you give us some background on what repairs (if any) or if you've gotten your system wet.
by Dan
Dan,
Replaced the screen assembly about a month ago. Replaced the battery a few weeks ago. Everything worked, it seemed, after both repairs. No water damage. I should have included that in the original description! Sorry!
by revborghardt
Are you certain the display assembly is aligned correctly? It's uncommon, but I've a few cases on other laptops where the display assembly was misaligned and not making proper contact when shut, so it didn't go to sleep.
by Zach
@zpl The display assembly appears to be aligned correctly. It opens and closes lining up perfectly and flush. How would I know that it wasn't aligned if it appears to close properly? Thank you so much in advance.
by revborghardt
