Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
iPhone 3GS keeps Searching for network/signal!
Hi,
I've an iPhone 3GS on which I broke the yellow prong which connects the board to the white breeze and gets the signal from the network... I had a 3g board which didn't work, so I took it's yellow prong and put it on the 3gs... but it doesn't work., keeps searching for signal
is there still any chance to save this one? :)
Score -1
2 Comments
when you reattached the yellow prong did you clean the square or scratch it to get to clean trace? how did you stick it on?
by
yuph, I glued it back, so there might a chance of some glue has come in between the metals? :(
by
Add a comment
Chosen Solution
You need to solder it back on. Glue is not conducting your signal. This is an easy job for you to do yourself if you know how to solder. Otherwise get a friend/dad or pop in to a radio/tv/phone repair shop and ask them to do the job
Score 4
Add a comment
i recently have same problem...just FIXED week ago. Mine was 3Gs on Ios 5.0 Ipad Baseband. i accecdently uptaded with Stock frimware.
and 3Gs kept Searching Network...BUT...It was even showing SIM Applications in Setting>Phone>Sim Application..
If u have Same Problem HERE is HOW TO FIX
u have to RE-FLASH IPAD BASEBAND with Redsn0w not Snowbreeze.i tried Sn0wbreeze it didnt work.
Download Redsn0w 9.9b7
Open as Administrator
Select jailbreak
click Next
Enter DFC MODE
next Select Ipad base band only...Dont select any other option like Install Cydia or Deactivate...
NOTE : This process only upgrade ur base-band not iOS so u dont need any iOS Frimware file.
If u r Getting 6000 ms problem in Redsn0w then u r trying to install iOS Frimware. U can Later install iOS any version with Sn0wbreeze.But for Now just install Ipad Baseband.
Update
Select jailbreak
click Next
Enter DFC MODE
Score 2
1 Comment:
I had the same trouble and I got it fixed.
thanks to 'Agha qazalbash Dec 10 2011 @ 3:53 AM" I just read his post and reinstalled to the IPAD BB.
thanks,
Razo
by
Add a comment
I've got an iphone 3Gs.
Yesterday I updated it with ios 5.0.1.
Now it doesn't want to connect to network (no signal)
baseband 05.16.05
What can i do ?
thanks
Add a comment
Add your answer
Sami420 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 14,423
