Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Replaced display assembly, digitizer doesn't work in certain spots.
I just replaced an iPhone 4 GSM Display assembly (digitizer and LCD) and connected every cable correctly and fully. However, when tested, there are three small dead spots in the digitizer, particularly the letters o, i, and m.
What is wrong? and in the repair guide, it says to clean all connctions with a de-greaser but don't actually get them wet. How do i do that? I'm thinking debris in the connection is the problem. Thanks!!
Score 1
1 Comment:
I agree with oldturkey, you may easily have a defective digitizer. I would check the ribbons to see any micro tears are present as well. Another note would be, moisture can easily cause the digitizer to do funny things, but usually not deadspots.
by
Add a comment
eric, I did find that most of the non-responsive areas on a digitizer are actually caused by faulty digitizers. It is usually that the "grid" inside the digitizer is malfunctioning. It those cases only a replacement will fix it. Of course, always make sure that you double check your work etc. You can degrease the ends with a little bit of isopropyl alcohol, use anything about 90%, and let it dry for a few minutes. Also clean the connector the same way. Hope this helps....good luck
Add a comment
same problem , checked the digitizer on another iphone and its working , on my iphone i cant even slide to unlock , could be something on logic board ? , connectors are clean , everything is checked . It happend after 2 3 days after screen was replaced and fully working .
Add a comment
Add your answer
Eric Schloesser will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,495
