Why won't my MacBook charge?
My MacBook Air A1932 has stopped charging.
The charging port on the MacBook itself has minor black marks, almost like it got burnt.
Is there a part I can just replace to fix this?
I would recommend getting an inline power meter to monitor your charger and your systems ability to charge. Here’s one: Satechi USB-C Power Meter Tester.
To replace the USB-C connector block MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement and here’s the needed part MacBook Air 13" (Late 2018-Late 2020) USB-C Board
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,196
5 Comments
Are you sure this is your model? Take a picture of the damage so we can see Adding images to an existing question
by Dan
Yes, I'm positive that's the model number listed on the bottom of the MacBook. When I plug in the charger it doesn't do anything but if I mess with the cable I'll get the red battery flash on the screen for a few seconds and then nothing. The MacBook will not turn on at all.
by Bill
Have you solved this? Mine is doing the same :/
by jhovanatrujillo
@jhovanatrujillo Yes, I was able to replace just the USB-C board (it was about $25 from iFixit) and it solved the issue for me.
by Bill
@dollabillz217 - Don't forget to score and accept the answer!
by Dan
