Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Vibrate stopped working after replacing battery. Any solutions?
I had to replace my iPhone's battery, and now the vibrate function doesn't work anymore. I suspect I damaged some contact, because I replaced the little motor and it still doesn't work. The switch works, the "mute" icon appears on the screen but it doesn't work.
It being my first time opening an iPhone, I screwed up: I assumed you had to remove the silver rim, and after removing the two screws, tried to pry it open with the spudger, to no avail. I eventually figured out the screen thing, and replaced the battery with no problem.
I've looked everywhere online for a solution: the contacts aren't dusty, the logic board is definitely touching the motor's contacts, everything seems to be properly aligned and I don't see any damage visually. I also tried the "smack" solution (running iBrate and smacking the back of the iPhone), but nothing.
Any ideas of where to look for damage or what cable I should try to replace next?
Add a comment
1 Answer
Chosen Solution
There are several users here that have had the same issue as you. Allow me to direct you to this Answer. In my brief search of many versions of this problem, this seems to have the most amount of trouble shooting and repair information. While it's the iPhone 3G (vs your 3GS) the steps to diagnose and repair should be the same. Good luck!
Score 2
Add a comment
Add your answer
hello will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 4,722
