Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
My phone turns off when I put it in sleep mode?
it turns off after sleep mode .
like it will be on sleep mode and then if i dont use it within 2 minutes it will turn off. and then only way to turn it back on its to hold the power+home button for 15 seconds
Score -1
4 Comments
How new is your phone/battery? Is there any chance the battery is bad and it dies while in sleep mode???
by
brand new just replaced
by
Would it be tedious for you to go in and double check all your connections and your re-assembly? Also, do you have a multimeter? Give the phone a full charge, use it for half a day to whole day and then measure the battery voltage if you can. Reading voltage can help determine if a battery is no good.
by
lots of people buy a "new" battery..it wasn't made the day it was shipped! It has sat on a shelf in a wharehouse for some time, and they deteriorate.. check the battery
by
Add a comment
1 Answer
Chosen Solution
Replaced your battery.
Add a comment
Add your answer
Luis Garrido will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,425
