Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
My iPad won't turn on?
Hi!!
2017 model iPad, it won't turn on or charge.. I have put the iPad on a 24 hour charge, I have taken it off charge and then left it for a while, I have done hard reset (6-10 times) on chargeing iPad then left it an hour and then did a hard reset off charge, I have taped it on the back… I have changed the cables and plugs even socket, I have cleaned the inside of the charger bit… I need help, I am taking it to a shop on Monday fingers crossed, I just want to know any more tips?
Score 2
Add a comment
Most Helpful Answer
If you already swapped out the cables, plugs, and socket, then the problem may be a dead battery.
Score 1
2 Comments:
Dead battery - broken battery and should get replaced?
by
Yes, try replacing the battery. It may have lost it's ability to hold a charge over time.
by
Add a comment
Same here I tried them but they won't turn on and work
Score 1
Add a comment
Add your answer
ginaipad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 336
