Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
iPhone 3GS not charging after battery replacement & random Power-Offs
I have an iPhone 3Gs running 4.2 Unlocked on Tmobile.
I replaced the battery and followed all instructions. Im fairly tech savvy and it wasnt too hard and I think I would have known if I broke something.
I reassembled my phone and turned it on and the battery was at 83% and it will not charge. The battery Icon shows the symbol that its fully charged. I doesnt matter whether I connect it to my computer or Wall, it wont charge.
Itunes however does recognize it and sync with it, so I dont think its the doc connector. Any ideas?
And it seemed to randomly shut off and start back up
EDIT: Just tried puttin my old battery in, and it works fine, so obviously its a problem with the new battery.
Score -1
5 Comments
oldturkey is spot on.again!
by
Thanks, but I learned from the best on here ;-)
by
if you change it to an answer (it is THE answer) I can upvote :-)
by
Okay I will, but not because of the upvote. Just because you think it's a worthy answer:-). Just wish some of the people asking would be more responsive....."like pulling teeth"
by
Jordan : Does getting a new Battery solved your problem? I have the same problem with another data point to the issue that my replacement battery started charging for 2 days but again went to the charged Symbol mode now.. Shall I also order a new replacement if this is purely a battery issue?
by
Add a comment
Most Helpful Answer
Jordan, look through the Solutions listed below the picture of the device. you will find plenty of errors based on new batteries. It appears somebody somewhere create a bad batch of these. I would return the battery and get another one. Make sure you purchase from a reputable dealer. Good Luck
Score 2
3 Comments:
Thanks, I appreciate your help, what would be a good dealer? Any good sites?
by
Also, I forgot to ask, can I get a 1600 mah battery instead of a 1200 mah ? would it still work?
by
Yes it would. I do think that at this point I would suggest ifixit. I am not affiliated with ifixit and do not get anything from it or out of it. I do know that they stand behind their products and have read many replies on here about the service and if something goes wrong, they do stand behind their products.
iPhone 3GS Battery Of course there are many others and a good Google search would probably show those. Good Luck to you and your phone.
by
Add a comment
Jordan, the battery for 3Gs P/N(616-0435, 616-0434 & 616-0431) if you use the 3G battery for replace, that what happen. The apple icon will appear every 5 min. Try to get the right battery. Hope it work for you.
Add a comment
Add your answer
Jordan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 9,997
