Why my laptop won't turn on?
My laptop won't turn on. Here is the background:
I've first noticed my battery was at 0% all the time, even when charging, so I wanted to remove the battery and put it back in so maybe that solves the problem. And I did that, but while disassembling I pulled out my touchap wire so with the toucpad not working I couldn't click on the battery percentage without touchpad, so I didn't manage to see if I fixed the battery problem, but then… it turned off. I could power it back on but after a few minutes, again, it shut down. I powered it back on but fewer and fewer time passed until it shut off. After that the screen wouldn't turn although I would hear some crackling inside. After few more tries even the crackling dissapeared. When the cable is connected, the red led is on (next to the battery sign). When I press the power button, the other green led lights up, but dissapears after 2 seconds.
Any ideas on solutions/problem. If it is my fault (if I messed it up with static electricity while dissasembling, is there any way to prove it?
Thanks!
