Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
Score 1
1 Comment
Hi,
What is the model number of the refrigerator?
by
Add a comment
1 Answer
Chosen Solution
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
Score 2
Add a comment
Add your answer
Mark T. will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 46
Past 30 Days: 208
All Time: 4,289
