Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Why won't my home screen come back up?
2 days ago I was given my neighbors ipod touch. He had some data and apps i didnt want on it so i pressed the button that said delete all settings and data. Now it will turn on only to go to an apple that has a face in it, then it flashes white and does it again. Please help.
14 Comments
have you tried to restore it under itunes? Is it being recognized when you plug it in? Was it jailbroken? What model Touch is it?
by
Since it isnt turning on correctly itunes or my computer can't recognize it. Yes it was jailbroken and generation i have no clue
by
Do you have a number on the back?
by
As in a serial number?
by
on the back cover in the middle on the bottom there should be a serial number as well as a model number. It is very small :-)
by
Show 9 more comments
Add a comment
Chosen Solution
This could be caused by having previously be jailbroken and some of your files may have been deleted. You can try to force restore by following these steps The other thing you can try is to use a program like iReb or TinyUmbrella and kick your iPod out of recovery. Any of the above steps could probably reverse your jailbreak. iReb is available here and TinyUmbrella from here. Leopold suggested DFU mode which is better explained at this site. There is also a video on youtube that might help you. Well, give this a try and see what you get. Good Luck
Score 4
2 Comments:
Thanks man i dont know what i wouldve done without you!
by
You are very welcome and enjoy your iPod ;-)
by
Add a comment
Have you tried to turn your ipod in DFU Mode? Timing is the Key...
Score 1
1 Comment:
DFU, what does that mean?
by
Add a comment
Add your answer
Adam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 761
