Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
iPhone X: screen black but touch works and the glass isn't cracked
After a fall, exactly a 1 meter fall that touched the floor with corner of the phone, the screen turned all black, but the crazy thing is that the screen is not broke and the touch works.
On internet I didn’t found nothing like that, can anyone please help me?
thank you in advance!
Score 1
Add a comment
Chosen Solution
Hello Kristian
The first thing would be to open the iPhone and make sure everything is in place. Attentive to the necessary tools, they are not usual screwdrivers.
The iPhone X screen is OLED, this makes them more delicate than previous models. OLED screens are easy to break without breaking the glass too. With a good blow the OLED panel could be damaged and stop working while the glass is intact.
For this you must change the screen, there is no other solution.
Good luck!
Score 1
1 Comment:
Thank you a lot!
by
Add a comment
Most Helpful Answer
either something has dislodged inside the phone which needs connecting back together, unlikely as there’s small panels holding most things down, or parts of the digitizer (the part that's lights up the screen) behind the glass have broken in which case you need a replacement screen as they come together as one.
Score 1
2 Comments:
thank you! waiting for other answers!
by
@kristian.loshi no problem hope you get it sorted
by
Add a comment
It Could be that one of the flex cables that connects the iphone X screen to the phone is snapped / dislodged, open the phone and check note that you will lost waterproof capabilitys if you open the phone up alternatively you can take it to a repair shop which will diagnose the problem for free after that you can see if you can repair it
Score 1
Add a comment
how much would it cost to get it replaced?
Add a comment
Add your answer
kristian.loshi will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 71
All Time: 4,173
