Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Charging problem after LCD and Dygitizer change, no auto-dim,bat drain
So I cracked my screen and replaced it, right after I noticed that the unit is getting odly warm and battery drains verrrrry fast,(10% in 5 min) that is not normal... also when I make a phone call and talk the screen is always on and the auto dim light doesn't work. I disabled 3G, Data, Vibrate, Dimmed light to 10%, disabled notifications and location, airplane mode... SAME ISSUES :S.... Please give me some hints....
Add a comment
1 Answer
Chosen Solution
If the screen lock isn't working when youre in a call, then the proximity sensor is bad. You damaged the ribbon during replacement of the screen or you received a bad one. This could easily cause the battery drain. Try disconnecting the ribbon and see if it show similar symptoms (other than the proximity sensor not working). If so, replace the ribbon
iPhone 3GS Proximity Sensor Ribbon Replacement
Score 4
Add a comment
Add your answer
NIck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 791
