Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Can't charge or Sync
My iPhone will not charge while its on; it will only charge if the device is completely shut off! Also I can't seem to get it to sync with my iTunes. I replaced the battery and the dock input! The phone works just fine, but I can't seem to figure out the problem!
Score 1
Add a comment
Most Helpful Answer
First start off my making sure ribbon number 4 is fully connected. If that doesnt work you may need to restore your iPhone. Could you even do this due to the fact that you cannot sync with itunes?
Score 1
Add a comment
Yeah ribbon was just bad. I replace the wire set and now it works great! Thanks for the help!
Add a comment
Hi i'm having a similar problem. Didnt u replace the ribbon first time when u replaced dock input?
Add a comment
If the ribbon cable is ok - check if you broke that SMD element near Connector4:
No USB Connection after I broke little SMD element near connector #4!
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 2,933
