1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Questions View all
No picture, only backlight on MacBook Air 11"
Hello,
During Catalina update (coincidence) I lost the display picture and the reason seems to be some kind of hardware fault.
  • No startup chime, only backlight turns on
  • Resets of PRAM etc. didn’t improve the situation
  • No external display output (miniDP)
  • Already disconnected battery and display cable multiple times, no changes
  • When powered on the fan starts up for a few seconds 2 or 3 times then runs without stopping anymore while backlight is lit up
Any other chance to narrow down the reason a bit futher?
Thanks in advance.
Add a comment
1 Answer
Most Helpful Answer
How soon did you panic? The system restarted after what you thought was the finish point of the upgrade and noted this? And then you powered down your system right away?
If thats the case I fear you may have messed your self up!
Apple now upgrades the systems firmware for different issues. As an example if you where using Sierra beforehand then your system needed to do a file system update from HFS+ to APFS which does take a bit of time. The second is the systems firmware also needs an up date for the new file system to be recognized, and lastly Apple now stores malware and other nasties signatures as well here’s more About background updates in macOS Mojave
So what to do?? At this point restart your system and let it be! Let’s see after a two to three hours if the system will recover its self, if it won’t then you’ll need to visit an Apple Store so they can use their magic to fix this.
Score 1
1 Comment:
Thanks. I did ‘panic’ after several hours with only the backlight lit up and no more response. Unfortunately also waiting for many hours after restart does not change the situation. I’ll visit the store.
by
Add a comment
Add your answer
Mr Flexxo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 7
All Time: 55
