Samung 28" 4K UHD Monitor. Model #LU28E510DS/ZA.
5 Questions View all
Can I add my spare samsung tv speaker on Samsung U28E510 Motherboard?
I have Samsung TV speakers & want to add these on Samsung U28E510 monitor Motherboard. Is it possible if Samsung U28E510 Motherboard have the audio port to add these speakers? Pls find the mother board picture I found on ifixit site for Samsung U28E510 Motherboard . Is this motherboard have the audio amplify port to connect Samsung TV speakers?
Update (10/13/2019)
Add a comment
1 Answer
Most Helpful Answer
Robin Singh  possible but we need to see the main board. You can probably connect it to the audio IC if it is amplified. Post some good pictures of the board with your question so we can at least try to help you further Adding images to an existing question
Score 1
5 Comments:
Not a good picture to identify the IC's but that board does not look like it has an audio amp. Can't really see it to well. Maybe take another picture just brighten it up and enlarge it.
by
Pls find below URLs for motherboard picture & you can zoom it. https://d3nevzfk7ii3be.cloudfront.net/ig...
Samsung U28E510 Motherboard Replacement
Hope this will help.
by
does your monitor have speakers right now?
by
@oldturkey03 - No, only one audio jack for earphone. Want to install existing Samsung TV speakers in this monitor if possible instead of using external speakers through audio jack . Thanks
by
Robin Singh you can't unless you get an amplifier first. Your board does not support speakers. You need an amp that you could install by the headphone jack and then install speakers. As is, does not work.
by
Add a comment
Add your answer
Robin Singh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 204
