The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Door lock light is on, will not allow machine to work?
The instruction printed below the light states press hold button for 3 seconds to unlock. Of course that doesn't work. I unplugged the machine and plugged back on, still won't 'unlock'. I hope this isn't going to be an expensive 'repair'.
Score 2
Add a comment
1 Answer
Chosen Solution
Leslie,give this a try "DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times." the service manual is available for a limited time right here and page 6-8 has the info. Good Luck
Score 2
Add a comment
Add your answer
Leslie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 21,337
