MacBook Pro 13" (A1278) won't turn on unless batt disconnected
I am CompTIA A+ Certified since 2016 and I have made many repairs on PC laptops and desktops, such as LCD screen and motherboard replacements, etc.
This is my first Macbook. It won't power on when you push the power button with the MagSafe connected or disconnected. My customer did not report any spills.
At first I thought maybe it was a bad battery or MagSafe AC Adapter. With the MagSafe connected I have a bright solid Green LED located at the L head, which would indicate a full charge on the battery. I removed back cover, disconnected the battery from the logic board, then reconnect the battery and when I connect the MagSafe to the system, nothing happens and I get no response from pushing the power button.
If I perform the SMC reset with the MagSafe still connected, by holding the Shift+Control+Option keys and the Power button at the same time then releasing all keys and the power button at the same time I see no change in the color of the little light on the MagSafe adapter. The light remains bright Green.
If I push the button on left side of case, I get all 8 LED's. If I remove the MagSafe from the Macbook and disconnect the battery from the logic board then hold the Power button for 10 seconds then reconnect the battery to the logic board the Macbook powers on immediately and boots to the logon screen, I enter the password and it boots to the desktop as it should.
I can disconnect the MagSafe from the system and it will remain powered on with the battery. Over time I can watch the battery charge percentage decrease or count down as it uses the battery. I can then reconnect the MagSafe and the light on the L head turns to Amber indicating a charging condition until the battery reaches 100% and the little light on the L head changes to bright green. I think I can rule out the battery and the MagSafe AC Adapter as being faulty.
It appears the battery is healthy and the MagSafe is operating as it should. Once the Macbook boots up it seems to operate fine so I think maybe the logic board does not have an issue. All the the other keys on the keyboard seem to function correctly. I am leaning towards replacing the keyboard which would also include the power button. What do you all think?
