Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
Replacement screen powers on but is black or white.
Hello,
I bought a replacement lcd and installed it according to the videos. The screen powers on but there is nothing displayed (black). I performed a few hard resets and a restore using iTunes. The phone is still "on" because I can switch is to vibe mode and it will vibe, I can also turn on voice command by holding the home button and it works properly. The kicker, however is that it used to be on but black. After the hard resets and the restore+firmware restore on iTunes, iTunes tells me that I need to insert my SIM card, which I do. After the phone powers up again, the screen is now white...
I have checked all the connections. I even unplugged all the way up to #7 in order and replugged them.
Add a comment
1 Answer
Chosen Solution
Sometimes you can get a faulty LCD (has happened to me a few times, very frustrating) and it will either not turn on at all or show a feint black screen or a very bright white screen. Contact the company/person you bought it off and request for a replacement and try again. If the problem still persists then you have possible damaged your logic board and that is a very big problem.
Add a comment
Add your answer
dorealex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 697
