Model A1285 / 8 or 16 GB capacity
206 Questions View all
Question Closed
4G Nano won't connect to Mac or iTunes
I have a 4th Gen 8gb iPod that works just fine, battery will hold a charge after a nights charging.. It plays the music that is on there just fine. Click wheel works just fine. I know that the cable it good, as it works fine with my 2nd gen. Basically everything works except there is no recognition by the Mac, iTunes, or the system info.
So I can do everything except connect it to my iMac to change out the music.
I have tried holding down various key combos looking for something different - but they all just boot up the iPad. I am not sure what key combo's to be using. Haven't found a clear description of what the combo's are and what they do.
I am getting to know these songs I can probably sing them backwards.
Any help greatly appreciated.
Add a comment
1 Answer
First I'd try disk mode, to see if the flash memory is at all readable through the computer, so follow these instructions to do that:
http://support.apple.com/kb/ht1363
If that doesn't work, you could try diagnostic mode (reset by holding menu+center and as soon as the apple logo comes up, hold prev+center). But most likely that'll not provide any sort of solution.
There are few parts inside an iPod Nano (click wheel, screen, battery, logic board) and if it is a hardware problem, it's almost definitely a problem in the logic board which won't be something you can fix (or replace economically).
Unfortunately there are quite a few different problems with the 4G Nanos, and almost all of them boil down to a logic board replacement.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,314
