Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Dropped iPhone 4, Touch Screen not working.
Hi
I dropped my iPhone 4 and now the touch screen is not working. I can see a hair line fracture in the panel behind the front glass panel. Everything else seems to be ok.
Please advise what parts would I need to replace?
Score 6
Add a comment
Most Helpful Answer
Sounds like the digitizer has been broken. You will need the following part to repair your device.
iPhone 4 (GSM/AT&T) Screen
iPhone 4 (GSM/AT&T) Screen Image
Product
$24.99
Score 1
1 Comment:
+ sure agree with that. The crack that is visible, probably destroyed the digitizer circuit...
by
Add a comment
If you have tried changing the touchscreen and still touch is not working, That means your phones touchscreen controller (IC) is faulty,
Score 1
Add a comment
The digitizer connector has probaly become dislodged slightly I have fixed many by opening the back and reseating the digitgizer cable. This is much more common when someone has removed the emi shield from the back of the board.
Add a comment
Yup, you just need the digitizer. The LCD and digi come as one part so it should be an easy fix. If your not sure how to see youtube or get a pro to do it. You can buy the part here on this site or try other sites like;
digiexpress.com
ipodrefresh.com
rapidrepair.com
Add a comment
Will replacing the screen fix the problem of the semi responsive screen problem?
Add a comment
i dropped my iPhone 4, it fell, the fall formation preceded by the lower part and its near the iPhone speaker and the bottom part of the screen does not work and this is the only part that is not working
can you give me some tips to fix my phone with that problem of it.
Add a comment
Add your answer
Anuj Mathur will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 10
All Time: 17,008
