Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1957 Questions View all
backlight, mute button and charging error message following wetness
Hey,
I guess I can join the club of getting my phone a bit wet. yay.
Primary problem: Intermittent backlight issues.
Most of the posts about backlight problems discuss a backlight that's completely burnt out, but mine works perfectly when I'm trying to unlock it and at a few other points. There are other posts with similar symptoms, but none of them have been answered.
Issue 2: Phone says I'm trying to charge it with a non-approved accessory, even though it's not plugged into anything.
Issue 3: Mute button no longer works.
I've had my phone in and out of a bag of rice for a few days, but the problems keep coming back. Any help would be greatly appreciated!
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Issue One - The reason your backlight (LCD) is intermittent is because liquid has made its way into the connection of the LCD and is causing it to short. Worst case scenario it has made contact with the logic board LCD connections, in this case it is unrepairable.
Fix One - Install a new LCD
iPhone 3GS Display
Issue Two - Once your iPhone has connected with a "non-approved accessory" it has the chance (due to a firmware glitch, thanks apple) to re-occur and annoy the *^#$ out of you. Also check the dock connector to see if any of the pins have been damaged. If so you will need a new Antenna Bridge Assembly.
Fix Two - Restore your iPhone
Issue Three - Do your headphone jack/volume buttons still work? If so then the connection to the logic board should be fine (Mute/vibrate button, volume button and headphone jack are run off the same circuit). It could be happening due to a drop or physical damage? If this is the case then you can either replaced the headphone jack assembly or just buy a new back assembly to save you the hassle of installing the headphone jack assembly.
Headphone Jack assembly-
iPhone 3G/3GS Headphone Jack Assembly
Complete Back assembly-
http://www.macfixit.com.au/shop/index.ph...
Hope this helps! :)
Score 2
Comments:
+ very nice and concise answer.
by
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 894
