Acer Aspire 3050 laptop.
9 Questions View all
Question Closed
Windows 7 Installed but cant alter resolution down to 32 bit...
I fitted a new hard drive and was given Windows 7 from a friend but when I installed it I noticed it was for a 64 bit. My laptop is a 32 bit. Is there any way I can change this so I have the correct resolution?
Thanks.
Add a comment
Chosen Solution
If the installation went through I doubt very much that your chipset and BIOS have a 32BIT limitation. I would search the web for any drivers you can be missing.
1 Comment:
Just checked and the Acer Aspire 3050 is 64bit.
by
Add a comment
Most Helpful Answer
heya,
the 32 and 64 bit are not the resolution of the screen. its the OS itself. so if you have a 32 bit system you´ll need the 32 bit version of windows 7.
http://en.wikipedia.org/wiki/Windows_7
http://www.lockergnome.com/windows/2009/...
cheers
Jan
Score 1
Add a comment
1st if his system would not accept the x64 it will not BOOT, so his system can be either x64 or x32. The resolution is caused by the lack of proper driver for his Video... it also can be because his does not have enough memory to allow the ability to change resolution.
lots more info needed to give 100% assistance.
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 2,151
