Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Replacing screen; Home button socket cant be removed
I was trying to replace the screen of an iphone 6 plus. I am used to the home button socket coming off with the big metal bracket. This home button socket cable is connected to the actual digitizer. Is it removable, can I replace the screen?
I am not talking about the socket being adhered to the plastic part of the display. The cable is attached to the digitizer. When I lift up the metal bracket, THE CABLE DOES NOT COME WITH.
3 Comments
Can you send a picture to better explain yourself?
by
That is from a 6s not a 6 plus but same principle
by
Add a comment
Chosen Solution
The 6s and 6 have different screens… do not try to pull the plate off with the home button flex cable under it.. I haven't checked the pictures but if u do have a 6s then do not try to remove that and make sure the screen u have is actually for the phone u
The 6 has a seperate home button flex, it has a metal back plate which is screwed into the screen assembly, the 6s has a metal back plate with another metal back plate behind that, u shouldnt need to ever remove the second back plate the home button flex is part of the screen assembly on the 6s… if u have a 6s screen and a 6 their not interchangeable u have to use the correct screen for the phone u have.
Add a comment
It’s just stuck down with adhesive. You can heat it and pull it off or use something to get under it with out damaging the cable.
1 Comment:
No. I dont think you understood what I said.
by
Add a comment
it is possible to remove. you have disconnected it and removed the screw.
you can slowly push the button down and use a plastic pry, at the same time, to remove the button. there is an adhesive strip that comes with it, it can be transferred to the new screen.
Add a comment
Add your answer
Briana Carpenter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 132
