Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
My iPhone 3G is not charging..?
I took my iPhone with me to India on my vacation. The voltage is 230V over there. I charged it couple of times there using wall charger. Then, while i was charging through the USB which was hooked up to the PC, i got an error message saying "this accessory is not compatible with this device" and it simply stopped charging. Now that i am back in the USA, i tried to charge the phone but it won't work. Can anyone help me to fix it. All suggestions are appreciated!
Score -1
1 Comment
Nikhil, just to make sure this is not going to become a red herring, when you charged it in India, what adapter did you use? Did you use one that is from there or did you use the one that you got with your phone. I am not sure if it would even fit, but just wondering?
by
Add a comment
Chosen Solution
usually this message pops up when the dock connector pins are dirty or damaged. try cleaning them with a brush to remove any dirt/pocket fluff etc. you can also try compressed air etc. then try again with the charger. If there is no change (ie message pops up occassionally) and the phone still charges and it is recognised by itunes then you can change the dock connector using the guide to the right (link is under the photo of the phone)
Score 4
3 Comments:
try replacing the dock connector
by
yep, just like pollytintop said...;-) good answer
by
I don't get the message anymore. Now when I connect the phone to the charger nothing happens. The phone just stays dead. So, I will change the dock connector and ll let you guys know what happens..!Thank you for all the help.
by
Add a comment
see this blog...
http://willy.boerland.com/myblog/iphone_...
Add a comment
Add your answer
Nikhil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,838
