Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
WiFi won't toggle on?
client came to me with the issue that her WiFi toggle had stopped working. Started from software level, reset network settings, checked to see if Airplane mode was on, hard resets, iOS reinstall, then moved on to a new WiFi antenna. Works for around an hour and then stops working again. Could this be the dreaded IC issue I’m reading about?
Add a comment
1 Answer
Definitely sounds like an IC chip issue. Take it to a local micro soldering repair shop and they should charge anywhere from 90-150 for the repair.
Add a comment
Add your answer
Isaac Wood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 73
