Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
How come I can't see anything with my new front panel?
I replaced a cracked front panel with the 3G repair kit. However, when tried to switch my Iphone back on, I can't see anything. If if turn on the silent button on the side, my phone vibrates, which must mean the Iphone is on but the screen isn't working.
I checked the connectors, but everything is fine. How is this possible?
Thank you
Score -1
1 Comment
Waw, it works!
Thank you very much!
Annelien
by
Add a comment
Chosen Solution
have you tried hard reset? press home and power for 10 seconds, apple logo should appear, then release buttons and allow to reboot.
Score 2
Add a comment
This job can be painful... Connector 3 is a swine to replace, I have found that the other two can 'pop' back off.
Its worth powering up to check before replacing the LCD assembly in the frame.
Just a thought
Add a comment
Add your answer
anneliendegadt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 823
