Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Lcd problem, flickers with pressure
So I fixed nearly every problem of this phone after disassembly now I have one that arised.. after I close the unit and I touch the top of the screen when its on the screen turns to random colors and basiaclly just fades out or stays white until I let go..
I tried holding in place cable #2 with no Vail.. What else can be causing this?
Score -1
1 Comment
Yea So i came to the conclusion that I fried the circuit, The screen no longer turns on and another screen doesn't work. The phone itself turns on fine, vibrates all that.. But the screen/touch screen never work.
I believe this happened because every time I changed up parts I never removed the battery connector and now the mother board circuit for the lcd is friend.. Anyone have any suggestions?
by
Add a comment
Chosen Solution
no.2 is the digitiser cable. try reseating cable no.1 which is the LCD cable...it needs quite a firm pressure to connect it and makes a pop/click when it's on. sometimes it pops up just as you close the display so keep an eye on it or put a flathead screwdriver on it to hold it down as you close the display
Score 2
4 Comments:
eh now the screen doe-sent even turn on, I think I might have fried the connector on the logic board ><
by
try hard reset..press and hold home and home button for 10 seconds, apple should appear then release buttons and allow to reboot. if that doesn't work.. does vibrate work? if yes then open again (i know this is tedious..) and put connector on again. if no then check all connectors again, make sure battery screw under sticker is in tight enough (not too tight)
by
me having this problem too!!!!!!!!!!!!!!!!!
I had to originally replace the screen being cracked an all, so I go to put it all back together with smiles(being very proud of me self) next minute white screen, nothing but white, I been unplugging, resetting cables but this number 1 cable very very tricky. still can't get me normally screen back - HELP
by
try the hard reset as above comment..
by
Add a comment
It is definatly the #1 ribbon cable that controls the LCD screen. I am still trying to figure out a trick to apply pressure onto it until i close my Iphone or maybe i will permanantly put something small to keep the pressure on the ribbon cable #1.
Add a comment
Add your answer
joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,470
