Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
I can't remember my passcode
i have a iphone 4 model number A1387 white phone i turn it on and swipe right and it tells me to put in my code . i cant remember my code so it goes to emergency calls only then if i try it more than 3 times it says wait 40 mins. what should i do
Update (11/13/2018)
what should i do
Add a comment
Most Helpful Answer
You should be able to put in in dfu mode and restore it in itunes. You will loose everything on your phone unless you backed it up though.
Score 1
Add a comment
Your options are slim here.
The only thing you can do is restore your iPhone to it’s factory settings using iTunes. There isn’t another way to do this, unfortunately.
Here is a guide on how to restore your phone to it’s factory settings.
https://support.apple.com/en-us/HT201252
Score 1
Add a comment
Add your answer
Kristina O'Connell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 73
