Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Where do speaker wires connect?
When I replaced LCD and glass I broke the blue wire to the speaker not sure where this wire should be connected, Audio is great to ear buds but need to get speaker working, need info on connection and how to get to the underside of board if wire is connected to that side of the board.
Thanks Dave AA6DB
Score -1
1 Comment
David Bird, take a good look at the guides on here and that might just give you the answer you need iPod Touch 4th Generation good luck
by
Add a comment
1 Answer
Chosen Solution
Speaker leads wires can be connected as follows, looking at the itouch with top away from you you will see two solder tips one on the left connect red lead the blue goes to the next solder tip to the right of the red one. Not necessary to remove board.
Dave AA6DB
Score 1
1 Comment:
David Bird, great job. All you have lefty to do is to accept your own answer. That way everyone will know from now on how to do it. Great job...
by
Add a comment
Add your answer
David Bird will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,479
