Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Questions View all
MacBook won't power on after display replecement
Hi,
I changed the display assembly from the macbook. After the replacement no image. The trackpad clicks when I power on the macbook but touch bar en green light shift does not work, no fans spinning. I can see an extern mouse is “working” when connected (red light from the mouse). 1 time the fans were running and another time I heard the charging bling (bling bling bling bling bling, … until i pressed power button). The GPU is getting hot (not extremely) when macbook is “powered on”
No visual damage to the logic board. What can be the problem and how do i fix this?
3 Comments
Can you tell us why you replaced the display assembly. What lead up to it and where did you get the screen?
by
MacBook had broken screen. Still working but lcd was damaged. From my chinees supplieer .
by
Check for shortage on the LCD cable or ribbon damage. Use the old LCD or a new one to plug into mainboard and see if you get image displayed. Did the OS boot up prior to the screen change? Try external monitor. Possibility of shortage somewhere on mainboard due to new faulty LCD cable or PC boards.
by
Add a comment
1 Answer
Most Helpful Answer
Disconnect the battery again and pull the ribbon cable going to the T-CON board from the logic board. Plug in an external display and see if the system starts up that way.
Score 2
2 Comments:
Just tested with the external display. Still the same problem...
by
I don't get it! The external should light up. I think the new display was defective and zapped your system.
While you don't want to here it I think its time to visit Apple see what they say.
by
Add a comment
Add your answer
Mattis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 122
