Tv won't come on
There's power and even the red light but it won't come on
this could be an issue with the power board, the main board or even the button bar. It is the main board that gets the signal from the button bar to turn on the power supply. So, you will have to remove the back from your TV and take a look at all the boards. Check for obvious damage like bulging, leaking capacitors, burned components etc. Post some pictures of your boards with your question so that we can see what you see. Use this guide Adding images to an existing question You’ll need access to a multimeter to try to isolate which baord has failed. Let us know the exact model of your TV
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 18
