Budget 15" laptop series released by HP.
261 Questions View all
Game Doesn't Want to Install
I have this game called Galactic Civilizations II gold edition, it was working fine until I tried to get updates. Well first off, the serial number doesn’t work so I went to the manufacturers site & they told me to uninstall it and install Steam & use The numbers again.. Well, that didn’t work either. So I tried to reinstall the game & all I get is this error: “The file E:\Readme.txt could not be Opened.” I talked to the local PC repair & they told me nothing & it would be $95.00 just to check it out. I can’t find anything on the web.
2 Comments:
Hi korhonen , first of all, what operating system is your laptop running on?
When you login to your steam account, did you managed to see the game in your account?
by
Estimado , la ubicación del archivo esta en otra letra , lo mas probable que el juego lo tenias portable , desintala todo registro del juego en instalalo por steam , así no deberías tener problema
by
Add a comment
1 Answer
Go to your steam folder
Default location:
C:\Program Files (x86)\Steam\steamapps\common
Find the game folder and delete it there.
Uninstall from steam after that.
Then try to reinstall the game.
2 Comments:
I Know It Has Nothing To Do With Steam..I Removed It After I Could not Get It to Work With The Serial Numbers To Work.Computer Is Running Wind 10..I have this game called Galactic Civilizations II gold edition, it was working fine until I tried to get updates. Well first off, the serial number doesn’t work so I went to the manufacturers site & they told me to uninstall it and install Steam & use The numbers again.. Well, that didn’t work either. So I tried to reinstall the game & all I get is this error: “The file E:\Readme.txt could not be Opened.” I talked to the local PC repair & they told me nothing & it would be $95.00 just to check it out. I can’t find anything on the web.
by
Tried to get updates for the game or windows?
by
Add a comment
Add your answer
korhonen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 56
