The computer won't turn on.
I have a toshiba laptop L300-st3501, when you plug in the computer it' won't turn on. i've tried charging the battery, but doesn't help.
melody, does your AC adapter work? Measure the output with a multimeter, just to make sure. the best way to see what and if anything is going on, I would plug it in after you verified that the AC adpater works, and pull the RAM one module at the time and try to restart it. You should also get a POST beep if you have no memory installed. This way you start off knowing that your CPU is working. Listen to beeps, listen to hear if your fan comes on. Start with the power first and take it from there and let us know what happens. Good Luck.
i have tried another adapter and it still won't work.
Have you tried the rest as well? did you remove/change the RAM? Any beep when you remove all of them?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,529
