A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Questions View all
I can't connect to an external display using a USB-C to HDMI adapter
I am unable to use an external display using either a MOSHI USB-C to HDMI (4K 60) or Insignia adapter.
So far I have tried:
  • Resetting NVRAM
  • Resetting SMC
  • Reinstalling system software MacOS High Sierra
  • Different adapters (MOSHI and Insignia)
  • Different HDMI cables that work with my older MacBook Pro and external display
  • Different displays
1 Comment:
What is the USB-C cable you are using? Some are not for data only power! As an example the cable you get with your system is a power cable for the power adapter.
by
Add a comment
1 Answer
Some hub/adapters are just finicky and refuse to work no matter what.
Some hub/adapters will work after Macbook will first go to sleep with the hub/adapter plugged in, enabling the video output on waking up. If you disconnect such a hub/adapter from the Mac you will most probably need to repeat aforementioned procedure again.
And some hub/adapters will just work no matter what, including the one made by Apple itself.
Add a comment
Add your answer
r.escallon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
