KDL-52EX701 - No image.video (including menus) - Sound OK,
Powers on fine, normally, including Beep, Green light.
Can hear the audio of the programs ( from Cable box via HDMI)
Screen is "on" and is dark blue.
I have searched through the forums and it seems like others have reported this.
I have opened and can not see any damaged components, Caps, etc.
Other posts mention A,B and C boards - but which is which? There is the I/O singnals board, the power board ans the T-con ( ?) the small control shielded board connecting to the LCD display.
I had found other info regarding a fuse (F101 on my board) -- my fuse was good. ( 0.2 Ohms).
Update (07/21/2018)
Images for reference.
1 Comment
Hello … OK almost 2 weeks…. if you are still there here is the data - so me the power looks fine.
I can take readings on the power board, but the Main board connectors are not labeled. So to say all of of the power reaches the main board, I can not see how to do this.
On the Power Board connectors
[image|1506523] (I have identified the Power, Main and T-Con)
Here are the V readings on the Power board side- relative to chassis
T-con on = 3.35
T-con Vcc = 12.65
Dimmer_DC = 3.35
Dimmer = 1.56
BL_ON = 3.07
BL_err = 0.00
Reg 12V = 12.66
Reg 12V = 12.66
Reg 12V_GND = 0.00
Reg 12V_GNG = 0.00
Audio 12V_GND = 0.0
Audio 12V = 12.69
Power ON = 3.29
AC off DED = 3.33
Stby 3.3 = 3.33
After this I plugged in an HDMI feed, and was able to change input from the remote so the sound comes on but no picture. Same as original problem.
by Paul Moore
