Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Autofocus iPhone 6S can't focus
Autofocus can't focus with rear camera. This results in blurry pictures and "shaking" pre-view.
I have noticed that the lens in the rear cover has a scratch which probably causes this effect.
Should I replace the whole rear camera (and includes this replacement also the outside lens?) or is there an option to replace the rear lens only ?
Add a comment
Chosen Solution
the rear lens is integrated into the back housing for a 6S. it is, by all means, possible to do, but much more difficult to remove than most people give it credit for.
my suggestion would be as follows; order both pieces. (the lens would only be another 99c. or so.) but try starting with just the camera replacement, in hopes that it is a module failure, and check if that fixes the issue. if it doesn't, move forward from there.
Score 1
Add a comment
Thx for you quick response. one question left.
Q: Iphone is remotly analysed by Apple Support and reported no hardware failures. Would you advise to skip the camera replacement and go for the rear lens only ?
1 Comment:
no, i would not. all the wireless analysis does is throw a voltage to each component, and make sure they get a voltage back. ive had apple tell customers that their phone is unrepairable, then i proceed to replace the battery, and its good to go.
i would never take apple diagnostics as a solid answer.
by
Add a comment
Add your answer
EdLochem will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,086
